pHeeL tHiZ ViBe
- Mazdaspeed6
started..and now no compression..cam timing? i don't know..well atleast it started once! good luck.
cam timing will easily throw off compression. which cylinders were registering low or no compression? what were the numbers on the other two cylinders? exact numbers on all four?
thanks Ken. Does a leak down test require pulling the entire motor again?
the car started perfectly and then it shut off and wouldnt start. Theres no compression in 2 out of 4 cylinders so everything is getting check out.
These engines have been known to jump chain and throw timing. It is a well documented issue, typically from low oil.
so the cams were overtightened or torqued down wrong?
Alot of times the shims will seat on a new motor, or the cams will settle in their journals and throw off the shims...
You obviously had a valve open at TDC...
This happens all the time on bikes when the shims are thrown out of spec...
