That happens when you use a spring that is too strong, and you have to "adjust" other valves, the only spring that should be used is the yellow spring. It's not that hard to even change the spring, screw off, screw on.I would imagine no celo. The map is behind the throttle plate so the cars sensors probably don't even know its happening. (maf doesn't read pressure)Mazdaspeeds don't need hard pipes, or there isn't a place to put them really. The Forge valve isn't so great. You have to change springs to get the perfect tension to vent and I understand that for small psi numbers the forge doesn't even open.
