With CPE Standback do you still need a fuel cut killer
look harder... its on ************ and ********** there are 3 cars that blew WITH the standback installed.
with the stand back installed on what map @ what psi??
laloosh said:
laloosh now your chaning turbos, so you need tuning. Stock turbo does not need it.
As to all thes ms6 guys blowing up...where are the links?
and stock turbo DOES need it, if you have even just an intake or an exhaust
i got the idea from you!? weren't you running a MBC after you put your turbo on, since the stock solenoid was faulty or something
yea and it sucks, thats why as was asking how to do it! i had my MBC conected but i was hiting fuel cut! i conected the stock solenoid good and no more fuel cut! even thou I have to agree so far the MBC let me boost higher and not loose so mutch boost between shifts! but the difference is that i have to change the WG settings now! and then it will be better!
oh i see, so you are sticking with the stock solenoid, and adjusting your WG?
i think you should try to reconnect the MBC and get the new CDFuelPump upgrade, and run the MBC at high boost
