mazda 323 wagon BF - 343whp
well look at the diff , its insanely huge. the shafts are HUUUUGGE......even if it breaks theres 4 boxes up the road for 400 each...no fuss
I'm being a smartass mate.....everytime i've seen you at willowbank, you've succeed in breaking SOMETHING....if not the gearbox, you'll do the engine or something next ;)
really dunno why you stay in teh street class, you are already almost as fast as the top of the front mod pack, with slicks and more power (now that you've got a tranny that'll hold it) you'll be low low 11's i reckon.......dunno how much longer you can keep forcing that much power though radials....
throw the BPT out..built FS turbo for the win ;)
yes that is tru , but its more of a challenge..im going to get decent semi's now..i might get some full slicks too and try both
Did someone say something about breaking gears?
Here's my 4th gear. WOT @ 19psi + water meth = too much torque.
(attached video requires divx codecs)
  • 4th_gear.avi
    4th_gear.avi
fair enough - i just wanna see a mazda put away the record currently held by that annoying little suzuki!
the lsd is sold
as for the suzuki - i think dave is always going to be ahead ..im not fussed as im not aiming for 10s as it needs a cage then etc..ill try beat his 11.2 tho
well the mr2 box is all running and in the car , now weighs 60kg more!
anyway the new ET streets hooks good for 1.9 60fts , however the ratios in 3rd and 4th are a little tall and bog however i did a 12.204@123 very easily anyway , im gonan change the ratios later if the new gt3071 twin scroll i just got doesnt boost the mid range up....
60kg....insane.
You'll need to make some more power to compensate for the extra weight :)
i had the car dyno'd a few months back and got 359.3hp at the fronts on a dyno dynamics just for interests sake , racing it next weekend
wow, its nice to see a fellow BF blowing others out of the water. :D
Im hoping to be pushing 300 WHP by this time next year on a built B6T.
Good Luck, im cheerin you on!
i used a b6t FWD BF gearbox (g series) with a straight cut 3rd and a special LSD i got from a mazda circuit car
