I didn't want to post it up, but here we go:
I bought the Unichip slightly used 2 years ago and after installation, it has ran flawlessly.
The problem started occurring intermittently in June, but did not become a serious problem until early July. The problem is that when accelerating, the engine RPMs would bounce all over the place. Even with a steady foot trying to hold a certain RPM in NEUTRAL, the RPMs would just bounce up and down. (I have a video of this that I will post up). The weird thing is that it idles perfectly fine. This happened several times, but the two most serious times were on the highway. I would slow down because of traffic and when traffic cleared up I would start accelerating and the RPMs would bounce so much that the car was basically jerking until I could pull over. The feeling felt like fuel cut or a fuel delivery problem. This happened several times on local streets as well. I had to disconnect the battery terminal to reset the ECU. No CEL ever came on.
The reason I said it was isolated to the Unichip is because the last time I was stuck on the side of the road, I had no choice but to pull the Unichip out of the car. Afterwards, the car ran fine (albeit not as smooth/powerful without the working Unichip). I checked all my fuses, relays, spark plugs, vacuum lines, etc, and did not find anything wrong. I reinstalled the Unichip a few days later, but came across the exact same problems. I pulled it again and it has been running fine for several weeks without the Unichip. At first, I thought it was the hot weather that caused the bogging/jerking. But the other major time it happened on the highway, it was 65F outside at night and the same thing happened. My car has been running perfectly since I took it out.
I sent the Unichip in to get looked at in early September. It was obviously out of warranty, but the sad thing was they weren't even going to look at it without charging me a ridiculous amount of money. I basically wrote in and said that if you care about your product and stand behind it, then find out what went wrong. They haven't answered back.
So I'm just sitting here waiting for their reply. I wonder how long it will take....
