CX7 Florida said:
Hello I have a 03 Protege 5 Sport Auto with 53,000 what do i need to do as far as maintenance ??? and tune up?
50K-55K
<TABLE cellSpacing=0 cellPadding=5 width="100%" border=0><TBODY><TR class=stripe-four><TD width="25%">Check level </TD><TD width="55%">
Coolant</TD><TD width="5%"></TD><TD align=right width="15%"></TD></TR><TR class=stripe-five><TD width="25%">Change </TD><TD width="55%">
Engine oil</TD><TD width="5%"></TD><TD align=right width="15%"></TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Hinges, locks & latches</TD><TD width="5%"></TD><TD align=right width="15%"></TD></TR><TR class=stripe-five><TD width="25%">Check operation </TD><TD width="55%">
Lighting</TD><TD width="5%"></TD><TD align=right width="15%"></TD></TR><TR class=stripe-four><TD width="25%">Replace </TD><TD width="55%">
Oil filter</TD><TD width="5%"></TD><TD align=right width="15%"></TD></TR><TR class=stripe-five><TD width="25%">Check level </TD><TD width="55%">
Power steering fluid</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Wheels & tires</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Check fluid level </TD><TD width="55%">
Windshield washer</TD></TR></TBODY></TABLE>
60K
<TABLE cellSpacing=0 cellPadding=5 width="100%" border=0><TBODY><TR class=stripe-four><TD width="25%">Check operation </TD><TD width="55%">
A/C compressor</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Check operation </TD><TD width="55%">
Air conditioning system</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Replace </TD><TD width="55%">
Air filter</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Change </TD><TD width="55%">
Automatic transmission fluid</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Ball joints</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Inspect </TD><TD width="55%">
Body nuts & bolts</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Brake lines, hoses & connections</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Inspect </TD><TD width="55%">
Brake system</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Chassis nuts & bolts</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Check level </TD><TD width="55%">
Coolant</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Cooling system</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Inspect boots & seals </TD><TD width="55%">
Drive axles</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Drive belt(s)</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Inspect </TD><TD width="55%">
Emissions hoses & tubes</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Change </TD><TD width="55%">
Engine oil</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Inspect </TD><TD width="55%">
Exhaust system heat shields</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Fuel lines & hoses</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Inspect </TD><TD width="55%">
Hinges, locks & latches</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Check </TD><TD width="55%">
Idle speed</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Check operation </TD><TD width="55%">
Lighting</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Replace </TD><TD width="55%">
Oil filter</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Check level </TD><TD width="55%">
Power steering fluid</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Replace </TD><TD width="55%">
Spark plugs</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Inspect </TD><TD width="55%">
Steering</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Steering linkage</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Replace
Timing belt</TD><TD width="5%"></TD><TD align=right width="15%"></TD></TR><TR class=stripe-four><TD width="25%">Inspect </TD><TD width="55%">
Valve clearance</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-five><TD width="25%">Inspect </TD><TD width="55%">
Wheels & tires</TD><TD width="5%"></TD><TD align=right width="15%"> </TD></TR><TR class=stripe-four><TD width="25%">Check fluid level </TD><TD width="55%">
Windshield washer
http://www.edmunds.com/maintenance/maintenance.do?step=step2&year=2003&make=Mazda&model=Protege5&style=4dr+Wagon+%282.0L+4cyl+5M%29&mileage=50000&engine=4INAG2.0&transmission=AUTOMATIC&zip=40219&synpartner=edmunds
