eyelids paint code????
snooky
Mazdaspeed6 GT
So i just bought a pair of unpainted ABS eyelids for my MS6. i need to paint them myself and was wondering if anyone has done this mod? what is the best compant to match paints? do i just spray and thats it, or do i need a clear coat?
thanks
I did mine with a can from AutoZone and it was pretty close, not as good as Taylor's though.
yeah, most of their paints are 2 step paints that you have to clear coat. I probably put on 3 coats of color and sanded inbetween and then about 3 coats of clear and wet sanded. Then you just get some 3M rubbing compound and buff the s*** out of them.
wow it really looks dead up, really nice did you have to clear coat it after? and have may coats did you spray
Also, the metal flake in the rattle can actually matched the OEM paint perfectly :D
see i have no clue how to do that, i thought it was just a spray and thats it.
why do you sand it?
and does wet sand make it shiny?
You sand it to get any imperfections in the paint out and make it smooth. Wet sanding is a way to do this without strippin the paint.
Its actually quite easy, this was my first time doing any kind of autobody paint.
My advice, follow their instructions and buy everything they list in the instructions (some of it you can buy locallly for cheaper like the rubbing compound and different sand papers)
http://www.paintscratch.com/spraycan.htm
Primer, Basecoat, Clearcoat.
*bump*
guys please post pix of your eyelids painted and mounted, i wanna see what the end result will look like.
thanks
heres a snap of my new eyelids
