Turbo oil?
Thanks man, have you got a link or somethign to get me started? A search didn't reveal much...
http://www.mazdas247.com/forum/showthread.php?t=123670983&page=2
post 26 shows the toyota gearbox sandwiched in there....
Unfortunatly Ross is a secretive guy...he wont give you anything over the basic clues to get it to work....but any resourceful mechanically minded person should have very little trouble getting it together...
edit---
before you go off trying to find a box, make sure you can get the thing to fit! not sure what the space requirements are...and whether everything will clear.
Also the MR2 box is only 1 solution. a honda box off a H22A would be my choice simply because its also a solid/direct shifter not cable shifted..but would require more customization to get a fit...
So what exactly are the limits to our trans? What I meant to ask is what HP are they breaking at? Hopefully we can run at least 270whp if u granny shift and not drag from a dig
I was probably around the 375 HP mark on race gas...
I would say so. I've eaten both an SRT-4 stage 2 with mods and an STi both from a roll with no probs...
Nice job wish I could have been in the passengers seat when that happened.
What about what Wiked asked about the Royal Purple "Max Gear" for the trans? Would it be worth an investment?
I personally don't have any experience with the Purple, but I can speak well for the redline MT-90.
ok getting back to Mobil 1 full synthetic.....do you guys recommend 10W-30 over 5W-30? because I just dropped turbo kit in my car past Friday and didn't think anything of it and put 5W-30 mobil 1 as I usually do.....
I mean, oil changes will be at every 3k miles now anyways, but just to verify, should I switch to 10W-30 instead of 5W-30?
Used Royal Purple 5W-30 oil for the p5. And this MSP has Mobil1 10W-30.
REdline MT90 all the way.
why is everyone (seems like anyway) running a 10 cold weight multi viscosity oil?
Mobil 1 5w-30 here.
