Rca's on Bose HU??? No right?
sierra248
Contributor
2007 MazdaSpeed3
My buddy swears his speed3 had Rca Outputs on his Bose Mazdaspeed3 Stereo? I know this has been covered allot, but after reading allot I can only find one post where someone says it does for sure. Can someone please end this argument for me, I live in FLA and he lives in Georgia, so theres no way I can go look just for this...but i was temped.
Thanks guys,
Tom
Oxymoron said:
OK if i buy this gadgetfrom Kenwood can i basically hook up anything to the stock MS3 Bose and NAV.
Kenwood's Carpotal KOS-V500 Expansion Solution lets you can build the ultimate A/V system without replacing your the factory system. Add high-speed iPod control of both audio and video. Enjoy navigation, satellite radio, Bluetooth technology, and HD Radio, and much more. The KOS-V500 even includes two relay control outputs for control of garage doors, gates, trunk releasesthe skys the limit!
Interfaces with Factory Radios to Build the Ultimate A/V System
Control with the KOS-L702 touch-screen
Control with the supplied remote and use existing LCD screen
Selectable AM/FM tuner with RDS+
Can be used as a stand-alone source with KOS-L702
USB Port for iPod or Compatible Player
High Speed iPod Control of Audio and Video
Includes 1 AV input/1 output for Video Sources
Front, Rear and Sub (2V) pre-outs for Amplifiers
Reverse Camera input
System Es Crossovers
RGB input for Navigation
2 Relay Control Outputs: garage door, trunk, lights, etc.
4-Line text display for Satellite, iPod, USB, etc.
Satellite Radio Ready, Bluetooth Ready, HD Radio Ready
I've read that the outputs from the Bose headunit are line level. So, you should just be able to tap into the inputs to the Bose amp under the driver's seat. As long as the amplifier you are adding has high impedance inputs, it should be fine. Other solution is to add a line level converter at the output of the Bose amplifier.
Line out converter
Hi, i was wondering what an LOC from the stock head unit is, how it is used with a ( 2 or 4 way ) amp and what it actually does?
thank you
an LOC, or line-output-converter basically lowers the voltage of a speaker level signal down to something you can feed into an amplifier.
There are not RCA's on the Bose headunit, but you can add them without too much trouble.
I noticed this as well. I'm getting a lot of hiss on my install. Sounds great once the volume is above the noise floor of the hissing.
hm i tested my spliced in rca's with a stereo system and i didn't have any noise - maybe i'll hear it later when i actually install all of my stuff.
bose vs stock
OK, sorry to be on tangent, but are the BOSE HU and stock tuner HU the same beast.... because if they are I can at least tap into a preamp out, since both amplify externally.
....Or are the BOSE stereos different than stock head-to-toe? From stem to stern....? Meaning no preamp level outs on factory non-BOSE tuners (boom03)
