NGK ZFR7F agreed, 1 step colder for higher boost, gaped .28-.30. I'm also running them. I didn't notice too much of a change but they're the way to go!
isn't one of the two not extended reach as well. we really should be using extended reach like the factory specs.
hmmm looks like matrix was right....the only difference between the 1 that has -11 and the one that doesnt is that it says "extended gap"
extended reach, not extended gap, I think the entire plug sits lower into the chamber. i am not 100% on spark yet, that is still in my need to learn portion of tuning.
both plugs state they or "projected extended" which probably means they are longer but the one w/ the -11 says it has an extended gap like matrix said, just comes w/ a longer gap...
evilmonkeyMSP, just order them from Sam at *************.com and they should be pre-gapped, you just screw them in. I have em, they're great plugs.
theres nothing better than coming home from work and a package is on your bed! wo0t!!!
my coldpipe and relocation kit came in. finally get to use my bov, i just have to find bolts to mount it onto the flange.
