Been considering putting a boost controller, boost gauge and boost cut defender in my car, but had a concern or two.
My last car was also factory turbocharged with a relatively small turbo, and one of the first things I did for more power was install a means to turn up the boost (actually a wastegate actuator with a much tighter spring than stock). It was initially set up like the MS3... stock wastegate actuator had a weak spring, but then a solenoid would bleed off some of the boost pressure signal going to it to raise and control the boost.
the big drawback I found after installing the new WGA was that, since the turbo was so small, once I took control away from the computer, the turbo would spool way too easily... at low RPM and low throttle opening, which would cause it to go into surge. This was audible as a 'flutter' sound and also the car and boost gauge needle would shake. I had to learn to drive around this by either driving with very light throttle, or full wide open throttle. Also i could not floor the throttle until at least 3000 rpm. It sucked, and after a short time I decided it wasn't worth the power and went back to stock.
So... since the speed also has a small turbo I was guessing that the same thing would happen. But i haven't seen anyone here talk about this. So for anyone running an mbc, can you tell me if there is any similiar sort of problem with the MS, getting too much boost too soon and getting any kind of flutter, surging or other odd behavior?
Any info would be appreciated!
