New hear(couple of ?)
Hey there, purchased my MS3 about a month ago, got a couple of questions.
1.The rear tires are towed quite a bit inward, is this normal on this car?
2. Does the catless test pipe show any gains with stock exhaust?
3. Any advantage to getting an aftermarket bypass valve on stock vehicle?
And by the way great forum!
First "new hear" should be "new here", toe is the correct spelling reguarding an alignment. Your question answered by number, #1 I haven't noticed it on my car, if it was improperly towed to the dealer it may have sustained damage they could check it on a rack for you. #2 I think a few people were disappointed with the test pipe as the primary cat is in the downpipe. The second cat could fail totally and the car wouldn't pick up a malfunction so it probably isn't that good of a cat (or that big of a restriction). #3 they sound cool, there isn't a performance gain unless you have huge hp numbers. If you do not run "vent to atomosphere" you should not experiance any ill effects with the added noise.
