04-05 Transmission 1-pin Connector
http://www.mazdas247.com/forum/showthread.php?t=123681478
Orginally posted in the main forum. At first I was looking for an FSM so I can find out for myself, but maybe you guys know about the 1-pin connector in the mazda 3 automatic trans. is. Im doing a swap to a protege 5 but the mazda 3 trans. has one extra connector.
Is it the same as the 07? For the 07 I see:
6-pin Transaxle Range Switch
four 2-pin solenoid valve
two 1-pin solenoid valve
3-pin vehicle speed sensor
2-pin input/turbine speed sensor
Nope they switched the trannys after 06' >.<
