Maxx Mazda
Contributor
- Stock P5
maybe look into running staight water with water wetter. 98c seems kind of warm. i have yet to see mine past 88.
That's what I run and I still hit 250*F... With a PWR rad and high flow SPAL's.
Question. Should I worry about leaning out under deceleration (like getting on the gas, let off and then it goes lean)? It leans out and backfires. It sounds pretty cool but I figure it isn't a good thing, but maybe since I'm off the gas it isn't a problem
Does anyone else get an extremely rich condition [10] when they are cruising and have barely any pressure on the gas pedal? I'm talking like just weight of your foot on there to maintain speed. I've tried to figure out how to correct this, but can't seem to figure it out.
i installed my lt10 today, but when i try and start the car it does not crank. I checked all of my wiring and everything is as directed, but still it wont crank. I also installed the 550cc injectors today as well, and i do have a 550cc map already loaded. The microtech manual says its either the starter conection or battery dead. what could be the problem????
The engine cranks but won't start OR makes no attempt at cranking when in the start position? Make sure you have good battery voltage (12.6), then check and make sure the single wire going to the starter solenoid is connected. Maybe it got undone during the process somehow??
would a loose vacuum line cause it not to start.
