Solution To Flickering Fan Speed 2 Or 3 A/c
Weborific
I finally found a solution to MY A/C flickering on position 2 and 3 problem. Canadian dealer wanted $420CND + taxes. US dealer would be around $190US.
PROBLEM: A/C light flickers on position 2 and 3
PREVIOUSLY TRIED: Replacing switch, cleaning all contacts
RESULT: Worked for a day or 2....
SOLUTION: 1) Pull out each wire (1 by 1 so there's no color mix-up) using a tiny screwdriver to lift the tiny tab inside each wire housing.
2) Clean each contact with isopropyl alcohol or similar
3) Squeeze the connector closed with pliers
4) Re-install
Before doing this, I noticed that if I would pull the wire harness out a couple of mm, I would lose electrical contact completely (obviously). But what surprised me was that when I
would push the connector in SLOWLY to the point of just making electrical contact, only fan speeds 1 and 4 would work. I would have to push the connector in further to engage all
fan speeds. After squeezing my contacts, I now have the A/C light completely solid during ALL fan speeds, EVEN when I pull the connector out a few mm. So this worked for me!
Try it and post your results!! Put a STICKY too!!
EDIT: I JUST ADDED A PIC WITH THE PINOUT SHOWING WHICH WIRE CONTROLS WHICH SPEED... THIS MAY HELP YOU ISOLATE THE PROBLEM WIRE...
These are found behind the climate control panel. You have to pull off the front bezel, detach some wires and 2 cables found under the dash.
Well I'm away on vacation starting on Saturday...but definately gotta fix this crap! I wanna know if it works for others as well....
i need to try this. from what i heard this happens to a lot of people. mine works only on 1 and between 3 and 4. yes in between with a little tap to get it to turn on. but it still flickers except on 1 it stays on solid.
Mine only works on position 4. Even then I have to fiddle with it to get the damn thing to work!
Matt
Does the fan work from 1-3? Or is it just the A/C light that stays off from 1-3? I know the resistor pack is responsible for the different fan speeds, but not sure if it ties in with the A/C compressor. Doubt it...
i definetely gotta try this... mine flickers occasionally on fan speed 2. still works none the less, but i know it'll get to the point where it stops working
I'm in wildwood till the 19-20th of Aug. I'll pull it apart this weekend and see what i can do.
Thanks for the post!
Thanks for the How-To, ask the mods to move it. I replaced my whole circuitboard trying to fix this, and no dice. Now I'll do this one! :D
Nice!!! I need to try this! You just saved me a bunch of $$$.
