ooo, ok, so then your going to be in closed loop all the time. ok i understand that.
so in the directions, it is the same way to tune the car right? tunning the trimming ratios? do i do the same thing?
but what happens when your at wot? thats the thing i dont understand. if the car is supposed to go to open loop, whats going to happen?
and just to make sure im on the same page, 10 is neutral, under 10 will lean out the ratio and over 10 will richen it up. when you have a negative number, it means your running rich, and postive means your running lean. and the objective is to make the short and long trims to be equal to zero as close as possible right?
