Adding subs and amp
If you've got $15 you can figure it out.
Just buy an aftermarket head unit wiring harness.
Pop ou tthe radio and pop on the hanress. Then just isolate the factory wires that line up with the Grey and White Pairs of the wire harness. Those 4 wires are the + and - left/right channels. Tap all 4, tape them up and run them to the amp. Then solder RCAs to the end of those wires and go into the amp.
Bingo, you've got bass
Adding Amp/Sub
AlbanianDude said:
HI guys we are trying to add two 12's and using the stock radio and no luck with getting any sound can one of you help please.
go to Circuit City or Best Buy or any audio place and get a High/Low Converter
this created the RCAs you need to hook up an after market amp. its the closest thing you will have for the best sound quality with the stock system.
PS i recommend getting those bass knob controllers (i forget the exact name)
my two 10s always need some quick tuning when its hooked up to the stock radio.....
http://www.mcx7.com/showthread.php?t=1057
As I said in the other thread, thats not a good idea for a few reasons.
1. Its not required if you have a bose system
2. The bose speaker level outputs are notfull range and will F with the subwoofers signals.
oops ya, sorry i didnt realize it was going to be for the BOSE system.
That would be cool if someone who's done this could post the wire colors:)
