I have *NO* experience with modern audio installations and I won't claim to.
- BUT -
If I had to venture a guess: I would say that most "Branded" audio systems in cars (Bose, Infinity, etc.) are custom engineered and designed for that specific vehicle. They are not just grabbing "off-the-shelf" components that they already make... they are creating a "sonic experience" where the only goal is how the end-result sounds.
Back in the "old days"... they were popping radios into the dash and throwing "stock" speakers wherever they would fit. Upgrading to a higher-quality speaker or compononet could almost ALWAYS make it sound better because very-little thought went into the requirements or designing of such a system.
Nowadays... I am 100% sure that Bose (or other branded systems) will "Analyze" the environment and custom-design a solution for each vehicle. Because they already "know" the space and are building the system, they can taylor the configuration(s) to get the desired results. If you arbitrarilly try to enhance or augment such a system, you may invariably end-up making it sound worse or BREAKING it.
Unless, of course, you are also a trained professional that understands how these systems work together to produce the final sound(s).
What's my point...? I agree with what others have said - either stick with the original equipment... or gut the beast and use components that work together for YOUR needs - not tapping-in to what's there.
(but what do *I* know?)
- BUT -
