MS3 Bulb Guide
CAms3boy said:
Anyone know of a place to get a bulb guide for the MS3? Particularly the interior lights.
Low beam headlamp (halogen): H7
Low beam headlamp (HID): D2S
High beam headlamp: 9005
Fog/Driving light: H11-55W
Parking light: 1157
Front turn signal: 1157
Rear turn signal: 7440
Tail light: 7443
Stop light: 7443
High mount stop light: 921
License plate: 2825
Back up light: 7440
Front sidemarker: 1157
Map light: 2825
Dome light: DE3175
Trunk/Cargo area: 2825
Source: www.sylvania.com automotive lighting application guide
Parking light: 1157
Tail light: 7443
Stop light: 7443
License plate: 2825
Back up light: 7440
Map light: 2825
Dome light: DE3175
The Trunk on mine has a festoon type bulb in it, I think that Sylvania site has an error.
1157 for side marker? This does not appear to be correct as that is the same bulb as the front turn signal which appears to be larger. Anybody have direct knowledege?
1157 is for front signal. The side oval light is not replaceable. I removed mine and replaced with LED sidemarkers.
I just replaced my low beams with Silver Star Ultras. Whoever designed that metal wire retaining clip needs to be shot.
Note the 07+ has 9006 fogs. Not that you care since you are looking for interior bulbs. But just a FYI!
okay, im really looking into getting some HID lights for my MS3, what bulbe "types" do i need in order to use HID, for the LOW beams and the FOG lights?...ive never done this before and im not sure..
Thanks
how did you do it its f@$%in hard... i removed the wire on the left side and replaced the bulb but i cant get the stupid ass wire to go back on.
