My car (2019) has about 60k km. I started to hear noise when brake and i had to replace the rear pads and rotors. The outer pad of the driver side rear brake has almost none left but the inner pad has plenty still. The right side is slightly better but also has uneven wear issue. The sliding pin feels ok. Previously when doing brake job, I found the rear pads were stuck in the bracket and were hard to taken out and out back. Same for the new pads I got from dealership. I am wondering if the brackets have some manufacture defects because the OEM brake pads don’t fit. Without the polishing, they would stuck in the brackets.
Here’s one pair of the rear pads:
