here's the update for the past two days of purchases:
$100 - T25 oil feed/drain install kit from http://stealthmodeperformance.com/oil-kit.shtml (includes EVERYTHING)
$25.75 - stock MSP coolant lines and stuff (from terbow)
$70.12 - exhaust manifold stud/bolt/nut (yes, 1 of each), plus MSP coolant return elbow from OnlineMazdaParts.com
$45.99 - Oil Pressure Gauge from Prosport Gauges
$62.02 - Valve Cover gasket, radiator hoses, and a couple screws from OnlineMazdaParts.com
$36.39 - Function7 GT25 oil drain flange/gasket/bolts
$68.19 - oil pan bung for drain, 10AN oil drain line and two anodized black (yum) hose ends from SummitRacing.com
check first post of this thread for the scary total so far.. just to get up and running with a very basic 5psi msp turbo setup
So did the function7 oil drain flange work with the fittings you got from Stealth Mode? Also what size fitting did you get for your 45 degree coming off the turbo?
I didn't actually use a single component of the stealthmode drain kit in my install.. it's all still in the bag. I bought a different function7 flange (one with male threads) and made a braided steel drain line with fittings and braided hose from store.summitracing.com
I can get you part numbers and such in the morning, I'm sorry I haven't gotten around to finishing my detailed writeup of the turboing process. Was far too busy with school, but I should have time this coming week during my "spring break" between semesters.
