Anyone who is running the MPI Tuner and extra injectors can now do full O2 tuning. If you do not want to do any tuning of the stock injectors, this is for you. You will only have to change three settings and move a few wires. You will then be able to tune you O2 for complete closed loop AFR control. While every O2 clamp on the market clamps voltage only. Our setup will allow you to program the O2 output to control your AFR in closed loop. You will be able to get rid of any over rich stumbles cause by the O2 clamping hitting to hard. You can add as fuel fuel as you need as boost builds. It will work just as good in 5th gear 2 psi @ 2,500 rpms as 2nd gear 10 psi @ 5,500. Smooth fuel curve from idle to redline.
Anyone running the MPI Tuner can make the change over in less then an hour. Please let me know if you have any questions at all.
