Wiring Color help needed
2006 Mazda5 Touring
Hey all, I have LED turn signals to put in and the load resistors to ensure they work properly. However I have no idea which of the two wires leading to the turn signal socket is the positive feed. There is a striped and a solid color wire, which one is it? Also, is there a cluster ground for the entire assembly or should I run an independent ground to the load resistor? Thanks much in advance for any help...:p
Well I got them installed and as soon as I started the work I realized that I'm an idiot. There are only two wires, so you really can't screw it up. The badly photocopied instructions that came with them made it appear as though you needed three wires. Anywho, my rear turn signals are now blinding my fellow motorists LOL
Got them from the same place I get all my LEDs, SuperbrightLEDs.com. I went with the 3watt amber turns and 3watt dual intensity red stop/brake w/ three second flash. I will try to get some night shots up, but they really aren't anything special, just really, really bright.
