Will these wheels fit my MS6?
07MS6
Banned
Will 18x7.5" wheels with a 42 or 43mm offset fit my MS6 without problems?
Stock suspension & stock tires.
probably will need a roll, I had a local fender rolling meet and one of the other guys was running 18x7.5's +43 on his ms6. he did has 225/40's, but you should be safe and roll them
Well, for the most part if you don't lower the car you should be OK with 215s and 225s but if you load up the trunk and have two passengers in the back it will rub.
Pick something with a 48-55 offset if you want 225 tires and never want to rub.
Don't want 225 tires
I never carry people in the back & never load the trunk up w/anything more than groceries.
Then go for it. Worst case, you scuff up your tires and have to roll the fenders or sell the wheels for something else.
yes
i went with a +35 offset.
i had to do plenty of rolling in the back.
don't know why there's so much excess fender in the back...?
what if you wanna drop with coilovers and go with 42+offset 18x7.5 i have a great deal on enkie bortex and i was thinking about dropping also to make it look good.. most likely 215x45 .. will rolling lip just be inthe rear or also the front?
