No need to cut. Use a flat head and you can uncrimp and remove it.Any pics of the cut collars?
for the 2nd gen MS3 RSB, did you also use the MS3 end links?
b/c I don't like OE quality, revised bushings or not, and there are no aftermarket stock MS3 bushings when I last checked) I would recommend keeping the collars.
Unless the MS3 end links were free, I would advise just skipping it and use a better aftermarket replacement. The 1st gen MS3 links are thin like stock Mz5 but I'm not sure if the 2nd gen were revised. The suspension is as good as the weakest link allows.
http://www.mazdas247.com/forum/show...Mazda5-today&p=6184670&viewfull=1#post6184670
Sounds about right if you are sticking with OE bushing brackets. If you are going with aftermarket, Prothane being the only option last I checked, you will need to remove the collars b/c the Prothane brackets are almost twice as wide as stock. From what I can tell, both the FSB and RSB OE brackets for Mz5 and MS3 are all the same; the difference is the bushing itself and the diameter of opening to fit the appropriate bar. To further clarify, you will need MS3 end links (cannot use Mz5).OK, just to recap and clarify.... First Gen MS3 RSB and Bushings don't need the collars moved?
2nd Gen MS3 RSB and Bushing do need the collars removed in order to use on the Mazda 5?
That's good to know! I have never looked into the 2nd gen bar and it is possible and highly probably that Mazda upgraded/changed the end links and/or even bushing collars.The 2nd gen end links I had on my bar were MUCH beefier than the stock MZ5 links.
