Will 2007 Mazdaspeed 3 Wheels fit correctly on a 2010 Mazda 5???
Perfect fit with 225/40-18
So second question: Will I need a different set of Lug Nuts? I'm assuming they are 12mmx1.5, so I plan on buying matching black ones also...
The lugs nuts are not affected by the wheel you run. That's determined by the studs on the hub that the wheel bolts to. Unless you change the studs to something other than stock, you don't need lugs of a different thread pitch.
Let me rephrase my question:
I want to change the stock ones to black Lug Nuts. So what is the size of the Stock Lug Nuts? Thanks in advance.
Picked them up today. Outstanding Condition. Serious kudos to the seller for keeping them in great shape, who happens to also sell his MS3 Access Port...
Venom- Again, seriously awesome picture of your MS5. But I was wondering... It looks like you dropped it quite significantly, but before you did, did you have to roll your fenders? Are they rolled now?
Thanks in advance! And thanks for the confirmation on Lug nut size.
The picture i've shown you isn't my 5. I did roll the fender myself with the roller fender tool. Once i install my 8mm spacers i had to "reroll" them and it wasn't enough lol... so i pulled the fender out a little bit and needed to grind the place where the rear bumper and the quarter are coming together ... yes yes grind the quarter and the bumper, but nothing shows from the outside. But damn it looking good now with this set-up. Next rims will have a more agressive offset for sure, who said : Push to the limits lol.
Uhhh, I did not expect having to roll... to confirm, Did you have to do that with the stock suspension setup? Thanks again! ;)
If your running on 225/40-18 without too much weight in the back (big subwoofer box or heavy kids) you will not have problems. I was rolling Rx-8 rims last summer and i was rubbing before i dropped the suspension, after the drop no rub at all. Because the coil are stiffer. But the Rx-8 rims are 8" wide, speed3 rims are 7.5 i guess.
I haven't been on these boards in hella days... lol
Good lookin out VenomDesign...
Yo Vindikacione, you should NOT have to roll your fenders (front or rear) with Mazdaspeed3 wheels and stock tires, especially at stock height. I'm pretty damn low and I have yet to rub on stock fenders, RX8 rims and 215/40s.
