Well it finally happened, I got a flat. I went to change it and realized that the girl who sold me the car didn't mention anything about the lugnut key and I can't find it anywhere. Is it possible to get a replacement or does it just have to be drilled off??
Your best bet is to look for it...these are keyed differently for each set otherwise what is the use of the key nut in the first place...in you owners manual and associated stuff there should be a card with your lock number on it...you can buy a replacement key with the number from the card...otherwise you need to get all four off and replace them with a new set
they gave me a card with the key, there is number which you need if you loose the key call your dealer and ask them about it. only problem it would probally take a while to get the new key. a new set is 30$. either drill it out or it looks like you might be able to use some channel lock or vise grip pliers to get them off. just be careful not to f up you rims.
