Wheelguru
Jag61180
Mazda MP3 Yellow Mica
Hook me up, what prices? I need 19's that fit. I do not mind using the dremal tool, and I too will be going show.
Dame you gona put 19's on MP3 that's gona loog big, hope you dont lower the car eny more, i think 18's will do just fine :D :p
Will 19s fit our cars? i heard from someone that even with 18s you had to do some dremel work?!?!
19's huh? Man, my 18's scrub like a mofo. I used 18x8 with 225/40 tires. I guess if you use like 19x7 rimes with maybe 205/35's, dunno if they even make rims that narrow in 19's, then they would tuck.
Even with the dremel I couldn't get my 18's to not scrub, I had to take them off. It wasn't so bad with just me in the car, but if I had just one person in my passenger seat they would scrub when I hit a bump. More than 1 passenger was outa the question.
Okay,
Here is a little bit of wheel knowledge for you!
Offset is the key! An 8" wide wheel will fit if it has the correct offset +45 and up! The Mp3 and P5 have the same fitment concerns as the Current Prelude's. For the easiest fit using the 205/45/17 stock size.
7" ET40>
7.5" ET42>
8" ET42-45 Needs fender modification.
8" ET46> should fit no problems.
of course the wider the tire the higher the offset will need to be!
Stock wheel is a 17x7 with an ET55
Currently I have 17x7 ET40 with no rubs
on stock tires.
My Street wheels will be 18x7.5 ET42-45
on 215/35/18 tires
And my Show wheels are 19x7.5 ET45
on 215/35/19 tires
If you let me know the style you are looking for I would be happy to find you a decent set of wheels!
That's what I do!
Wheelguruuu@hotmail.com
