Whats up guys just recently changed out my front links with the ford escape ones. My questions is which links can i use for the rear, im in no need of fancy adjustable ones just stock ones or like the ford escape links. What do you all recommend, thanks in advance
But someone mentioned Deeza in another thread. Haven't seen those. Maybe they are cheaper non-adjustable beefier version like the moog escape ones are.............more searching
Found Deezas on Rockauto. They look maybe a bit beefier and are $15 range in price.............
Dude you can get them mad cheap off of rock auto, that's what I did. Btw if your lowered
I've seen on this forum that the ford end links will cause length issues. But if you have a rear sway bar I
Would say just get some really strong ones for the extra force it will be getting. I
Using shorter rock auto links in the back with a sway but feel like I should have gone with something stronger. So far so good though on rock auto links
i meant the energy suspension adjustables not being cheap. my car is lowered with progress rr sway and has no issues with oem length front or rear endlinks but if/when they need replacing they will be something better/beefier.
