Noticed the idle AFRs were getting really lean (and staying that way) as I was coming home from work. I get home and check things out and sure enough, one of the studs at the turbo flange has sheared completely off. Time to completely take apart everything once again and replace that stud. To make matters worse the stud is an adaptor - it has two thread types! Where the hell am I supposed to find a new one and now I'm worried it won't be strong enough. WTF?!
well if it makes you feel any better I have to remove my manifold once the replacement arrives. So thats a b****, but think I'm gonna have it installed same time as I get the intake manifold I get, which ever one, installed. So it will be worth it. And new fpr same time.
All within the next couple months.
Injectors to follow.
i started her up today for the first time in 3 weeks. the turbolife fmic install went a little longer than anticipated, but im pretty much done. bumper goes back on tommorow. i also installed rr racing front mm inserts during the downtime
Good replacement if the stock one is broken. But I don't think his problem is the wga. Can't really tell unless he's got a boost gauge. When mine went out I never had any idling problems. Just no control over how high the boost went. I spiked 18 a couple times accidentally. I'm sure it would have gone higher if I hadn't gotten off the throttle. It sure pulled like a mofo when it did that though, wish I had built the motor and unleashed that little T25.
oh really? i do have a boost gauge and it isnt boosting above stock levels so it is right where it should be. guess it could be a vac leak? i checked the t-bolt clamps and nothing seemed loose so idk
Well everything is removed again. At least the good thing is I'm getting good at this now, LOL. Now I just have to find some new studs. Does anyone know where I might be able to find some metric to SAE thread studs?
mcmaster.com they have it all.
Actually, I've been stupid. Why could I not just run a completely SAE stud and use the corresponding SAE thread nuts? I mean, I already know this size (either 1/4"-20 or 5/16"-18 I think) so why not just get studs in that size and use the proper SAE nut. I mean, it's going to be annoying to have to use an SAE wrench but it should work. It's not like the turbine housing is threaded or anything.
indeed. its easier to do it that way anyhow so u dont need specialty parts (adapter studs)
Got my custom Spicy shoes in that I designed, Still need to figure out the bumper issue with FMIC install.
Lol I love all these non car things being painted like MSPs. I should paint my mountain bike black mica.
