Water in rear vent
Mappy
Mazda5
2009 Mazda5 Sport - Recently there has been water sloshing sounds accompanied by water leaking to the passenger side and water spewing out of the rear vent onto my children. I piped some air up the AC drain tube to see if any blockage would become dislodged but no go. Anyone have a similar problem? Ideas?
AC moisture drain tube is clogged most likely, you can trace it from the condenser under the car and fish out the clog with a coat hangar. Make sure you turn the ac off when you're 1/2 mile from home and crank the fan to help blow out the moisture in the AC or it'll sit and grow grossness
I remember being able to access the drain tube after taking off the passenger kick panel. Should be white plastic with a black tube connected to it. See if anything comes out after shooting some air in that way (have towels or somehing to drain into handy)
