Hi,
I just swapped on my winter tires on to my new (used) 2006 Mazda 6.
The winters are on steel rims whereas the summers are on alloys. I used the closed-end lug from the summer alloys on the steel rims.
The fit seems to be good. There is no obvious wiggle or play. A little drive around the block at about 30-40km reveals no issue. All is good and right.
But, on reflection, I was wondering if this was a good idea. I am wondering if were possible to be tightening the lugs up against the lug end rather than against the rim. My worry was this: if the width of the steel rims at the lug holes were thinner than the width of the alloys at the lug holes, then it is possible that the lugs are tightened against the end of the lug rather than against the wheel. I small amount of play (and potentially undetectable by the heavy-and-wiggle test (tm) )) would make a difference under driving conditions.
Any thoughts? Thanks!
Best wishes,
Jay.
Best wishes,
Jay.
