Anybody with the 2002.5 install aftermarket tweeters? The reason I ask is beacause I wanted to know if they fit in that triangle area where the mirror is. Also does anybody know if I can buy those from the dealer since I have a 2002?
Now I have a few questions about installing amps. When you are installing multiple amps is it ok and safe to connect both power wires directly to the battery? I've read of people using a power distributor and connecting the power wires to the amp to that and the distributor to the battery. Also when you connect the remote turn on wire is it ok to splice both of them from the two amps together? I heard that if you draw too much power from the deck or something then the amps won't work.
