Turbo Timer and alarm question?
Speedplease
2003 Black GT Mustang
I have the Greddy full auto tt installed and was wondering if there is anyway I would be able to still set my alarm after shuting my car off. Ex being I cant set alarm while car is running and technically when my keys are out of my ignition my car is still running for a min, so I have to manually lock my doors but then my alarm is not set. So what im asking is; is there anyway i can still arm my alarm while the car is still running?
ya search i cant remember exactly. you need go to the alarm box, cut one wire and tap it into the wire right next to it. then go to the box under the black panel in the back and cut another wire. i cant remember the color of the wires. search andyou shall find my son :)
Here is the answer:
Yes, you can arm you alarm with your car running.
Under the plastic rear deck behind the seats is a small box labeled Naldec.
This is the factory keyless entry module.
Then cut the blue/white wire. there are 3 blue wires so pick carefully the others are blue/grey dont touch them. just tape up each side of the blue/white wire and your good to go.
This is all I did. It worked perfect.
Let me know if you have any other questions.
Tom(boomergt)
Ok where excatly is this box? behind rear seats, in trunk, passanger side drivers side? I couldnt find a box anywhere!
It is under the rear deck... Right behind the center of the rear seat.
I will go take a quick pic
I attached a pic so you can see where I am talking about. It is behind the red outlined box. You will have to either take off the rear deck or pull out the push pins and peak behind the deck.
Awesome Thanks a lot! Dude your the man that s*** took me all of like 2 min and it works like a charm!
I really do not know, I just cut what I was told. It works for me and nothing has screwed up so i dont think it was important. But I should start not being as trusting as I am and start asking questions before I just go out and cut wires cause one day its gonna get me in trouble! LOL
I have had mine cut for 20,000 Miles and still no problems... I found this on the forum a long time ago... I am also very trusting for some odd reason!
I am not sure what the wire is for.
