Turbo System Switch to MAM 2nd Gen Streeet Sleeper Kit
LinuxRacr
Contributor
2001 Mazda MP3
That's right, I'm fixing to change it up again to get the car running the way I want once and for all! Stay tuned for updates and pictures..
Here's a preview:
Ohhh Shhhiet! (shocked)
....Discreet And I will be heading up there this weekend, hope to see u guys.
I plan to. I already modified my turbo and cut this weld (pictured below) so that I can run internal wastegate again. Now I just need to clock it the right direction.
The rest is coming together. If 5 PSI can make 180 HP, I'm hoping that 16 PSI will make me proud!!:
Thanks ebmp5!!!
I re-clocked the turbo to accomodate the new turbular manifold, but need snap-ring pliers to clock the compressor side of the equation. In the picture below, you will see that the actuator rod for the wastegate is not lined up with the gate.
Thanks ebmp5!!!
NO DOubt man!!! good luck hope u have fun and let me no what kind of power u get after 7psi so sad that i didn't go past 5psi. i bet when u get that bar going u gonna see some crazy number's.
Turbo clocked. I still need to get my hands slim-line SPAL fans, and a couple of replacement gaskets.
Yeah, I definitely need the Spal 9 inch puller. I also need a SPal 12 inch puller. You have PM.
Fans Procured
Thanks to Carlos (dominoy2k1) for coming through with some fans! I hooked up the mystery 12 inch fan (I don't know where it came from!!) to a portable 12 volt battery. It almost blew my shirt off!! LOL! I haven't tested the 10 inch Spal yet, but I am asured that it works. Here are some pictures:
LinuxRacr said:
Thanks to Carlos (dominoy2k1) for coming through with some fans! I hooked up the mystery 12 inch fan (I don't know where it came from!!) to a portable 12 volt battery. It almost blew my shirt off!! LOL! I haven't tested the 9 inch Spal yet, but I am asured that it works. Here are some pictures:
I need those to cool my baby. How is everything up there my amigo.
I just checked the part number on that Spal fan you gave me. It is actually a 10 inch SPAL fan (VA11-AP8/C-29A) or (30100360). Do you know where the 12 inch can came from? It says "Hayden Automotive" on it.
