Transmission shifting to 3rd Only.
wrathyimp
Hi,
I having issues with my Mazda 6 2003 (2.3) transmission (its Automatic).
First My A/C was not cooling, go it checked, Seems the alternator (dynamo) was having burned out clutch and was overcharging, so replaced it and Added New Battery.
Now A/C in not giving enough cooling, again got is tested, needs to be checked for leaks.
Same day had issues in my transmission shifting, slow speed, lot of shocks and jolts.
Took for Transmission checkup, guy said for have a scanned results.
Now the scanner guy is saying my Alternator is again overcharging, giving 18watts/volts (dont know what is ment).
The mechanics checked the alternators, they also change 3-4 different alternators, and there is the same issue.
Now Please guide me if my transmission is busted or there is Electrical circuits, the Computer system is busted that is causing the shift problems, by not supplying correct voltage to the transmission.
