T25 Garrett turbo
Picked up this turbo from another member here but never installed it and have recently sold the car so I won't be needing it. Brand new T25 Garrett turbo with WG. Shipped with tracking info to your door for $575. Since I never used it I cannot verify how it fits whether its a direct replacement or if it will take some modifying.
Pic with website
Aight fixed pic with website, screen name, and date.
Just a FYI to the OP and anyone looking... the compressor side will need to be clocked 90 degrees to use on a MSP. If installed as-is, the compressor outlet will be pointed straight at the block. Should be pretty easy since it's a brand new turbo, and the retaining ring shouldn't be frozen up or anything. While you're at, you may even just want to point the outlet down instead of up for cleaner routing to a FMIC.
