Yello_Pro5
Hi,
I attached a picture describing the enclosures I have used before (# 1 and 2) and the one I think to build (#3).
The sub I'm talking about is a Pioneer TW-W31C 12" (150W, 400W max.). It is powered by a Kenwood KAC-606 amp bridged at 150W (if I recall correctly).
Now, I really like the way the enclosure #2 sounded but I don't want to use it anymore since I need trunk space. The #1 enclosure didn't sound as good (probably too small).
Pioneer recommends a 2.0 (+- 10%) cubic feet sealed enclosure. For the moment, I plan on doing it sealed and going with the recommendation. The question is how will it sounds compared to the enclosure #2? I really liked it because the bass was "smoother" then with the other that was too "punchy". Should I port it anyway? or stick with the recommendation?
Also, I know enclosures are typically made of 3/4" MDF. However I have some 5/8" plywood laying around, any reason not to use it?
Thank you
Thank you
