Splash shield in driver's side rear well destroyed by lowering car
So my car is lowered. Not a bunch. 1.5" from replacing my suspension with the Tokico HP kit a little over a year ago. I figured it was as close as I could get to OEM without paying for the retardedly priced rear shocks.
With enough weight in the back and/or a big enough bump, the driver's side rear tire rubs the plastic splash shield that covers the filler tube to the gas tank.
Mine now has a sizeable hole in it, and I get the playing card in a bike wheel effect when it rubs.
I finally found the part in the parts catalog, and it is Mazdaspeed specific and $93, as opposed to $13 for a regular Protege. WTF?
Anyway, there are a number of part outs on here that probably has it still, but I don't want to replace it just to put another hole in it and have the same annoying sound in a couple months.
Does anyone have a good solution for this problem? I've wondered if I could somehow zip tie back further away from the tire, or create something custom that gives me more clearance. I assume that is why it is Mazdaspeed specific in the first place.
I'll have the tires off again tonight, so I'll take a picture to better explain.
the rear splash shield / fender liner should be the same part as the regular protege. only difference in the rear is the bumper skirt, which has nothing to do with the splash shield / fender liner. you were likely looking at the front fender splash shield.
are you running an aftermarket tire set up? if you are rubbing on that part with a stock wheel-tire, you must have a TONNE of junk in your trunk.
No it is a different part number. I don't know why they would be different other than the MSP is lower from the factory.
9 Protector, Filler Pipe
DX, ES, LX, SE, MP3 Model B26H-42-298A
MAZDASPEED Model C177-42-298
With two 200lb guys in the back and four people's luggage in the trunk, it only takes the slightest bump to rub.
Even with nothing at all, a hard enough compression will rub such as coming down a ramp that quickly flattens out.
