Simulation
chdesign
Just for laughs my new setup versus the NA setup to give any of you an idea if you are debating between FI and NA.
(nuts)
I will once i get it all finalized...i just test fitted everything and took it for a test run i have some things to change and fix up first. I still need to plumb the wastegate into the downpipe..get everything coated, I may ditch the FMU and get a SDS controller, I want to finish polishing the compressor housing....so it might be a month or so before i get it all finalized....but it will be nice once its done....oh yeah i got an intercooler to fit in also and plumb it.....its a Saab unit but no tthe small blackstone one the huige blackstone one....its thin but wide surface area and according to Saab a 76%effiecency rate so it should work very well with my setup.
Projected WHP should be similar to spoolins stage 3 maybe better since i'm using additional injectors instead of an FMU so I'm looking for about 195-200 whp. As for pics all i have now is parts strung out in my shelves while things are getting reworked polished and whatnot i can post a pic of the bling bling in porcess of the polished ocmpressor!! :)
Here is the compressor housing its almost done but its still a work in progress....I still have to go over it with a white rouge compound to give it that final mirror finish.
