Shark Fin Antenna
Sharkfin antenna reception around here is noticably worse than with the stock antenna. Not really a issue with me as I listen to Sat radio all the time.... If your thinking of doing sat radio as well, you may want to look around, as a few people have run the sat radio antenna thru the regular antenna hole, and covered the sat radio antenna with the sharkfin for a really clean look....
How would i go about installing a shark fin antenna??.. the stock one is driving me crazy.. its the only piece on my car that i absolutely do not like.. even the amber side markers dont bother me as much as this.. is it a simple snap off and back on?? are there screws involved?? any input or advice is greatly appreciated.
all you do is unscrew your long antenna...then get the sharkfin antenna and you screw in a wire into the existing hole for reception and use double sided tape and press the shark fin down...it works very well...i have had mine on since april
If you buy a used one and need the 3M gasket, they are $7 from VG. Just go to their page and contact them and they'll send you the info.
just put on my sharkfin this week, super easy job, tape seems to stick plenty good, radio reception is fine for the stations I listen to, great buy
Could you send me some details on how to do this with the sharkfin and the sirius antenna?
As far as I know, I have yet to see a how-to for this. Several people have done it, but not really written the how-to in detail.
I just got my shark fin in and installed it the other day... what a great mod! I should have taken photos for a how-to but its very straight forward.
I first cleaned my car just because I do so every week lol, then I wiped the area clean making sure there was no dust or leftover water. I unscrewed the antenna, just turn it and it comes right off. I then took nail polish remover and with cotton balls really cleaned the area around the antenna (you're suposed to use some type of rubbing alcohol). Then just put the shark fin on (without the 3M first) and align it how you like, took painting tape and put it around it so you have a guide. then with a hair dryer heat up the area on the roof making sure its at room temperature (I did this mod in my garage and it was a bit cold outside) so the 3M sticks well. Connect the wire in the shark fin to the existsing antenna base, screw in the bolt provided with a flat head screwdriver. Take off the paper and put the shark fin on aligned with the tape you had earlier. Press down for a minute per side and your done!
For me, I noticed no reception lost in the radio... everything worked out great. Only thing is that it took like 4 weeks to ship lol.
