Seats installed: Corbeau A4s
changedman
Banned
Contributor
2001 Mazda MP3
I installed my seats today, what a cinch. From start to completion, it took a little over 2 hours for everything, harnesses, sliders,seats, making sure the harnesses werent twisted, etc.
The sliders are awesome, was very easy to install this stuff.
If anyone would like more information, PM me. Here are pics!
how come u mounted the belts like that? u need my pics? sorry -____-
looks good!
are those harnesses just for show or are you going to actually use them like that? plans for a proper roll cage down the road, maybe? (glare)
possibly a roll cage. who knows.
the way i mounted them is suggested and safe, as it uses a stock bolt to position. i might put it on the bottom later on, not sure.
ic ic, thats good :)
i tried to do that in the p5, but it doesnt reach. werent u getting the 4 point also?
Good job once again. very nice (hump)
i was going to but didnt want to have to fuss with another mounting position (rlaugh)
so i got the 3pt :)
also, you can see i am retaining 100% of the oem belts. I can use the oem belts whenever now, which really helps.
Ideal is 90 degrees back from the seat holes, but you can go to 45 degrees down. Anything lower is bad news.
So did it lower the seating position at all?
these brackets were "good/ok" i really had to try hard to get them all to match PERFECTLY. I mean it wasn't hard, but if you drilled the holes out a touch more, that would be perfect.
the seats lower the driving position a lot, i bet 4-6"
seats are nice i dont know about mounting the belt all high like that, on my 240 i mounted it inbetween the backseats upper and lower cushion thing like hwere the rear seatbelt bolts are, as i dont like it when there mounted to the back of your chair.
damn..where do you guys get the money for all these goodies!!!!?
looks very good on your car pat.
nice Pat.... so do you think that I could fit those TRS's in since the width at the base in the front is 2" wider? Does it bug you sitting lower now?
looks nice, but need a harness bar behind the seats :D, although if you gutted your car it would fit nicely like that hahaha
bryan, they require me to maintain two harnesses.
and joe, i doubt it- its a TIGHT squeeze now...
