This is what JDMSam states on his forum.
"The MSP cam gears, cam sensor, ignition coils, knock sensor, valve cover, intake manifold, injectors, fuel rail, main bearing support plate, oil cooler, cooler o-ring, oil filter stud, coolant hard lines, oil lines, and turbo assembly must all be swapped over to a non protege FS donor engine.
The only engines that are easily compatible are 00-02 626 2.0L engines.
DO NOT USE 93-97 MX6/Probe or 93-99 626 FSDE 2.0L. The designs of these older engines are inferior and require a lot more things swapped over to work properly."
