RX-7 Clears
KYREDP5
Contributor
02.5 Classic Red P5
Got my RX-7 Clear corners on today. Over all they work well, had to cut the lens backing some and had to cut the bumper a little bit. (Wish I knew where my dad's dremel was). My mom's got the digi-cam right now, assuming it's not dark/raining when she get's back I'll get some pics up. If not I'll get em tomorrow.
is there a big gap? What if you wanted to put the originals back on for some reason?
There is a small gap. I plan to get some new trim for around it next time I'm out. The origanals will still go on fine and dandy.
Got them off e-bay. Something like $30. Here's the pics. Like I saind I'm going to get some thicker rubber trim to go around them to hide the gap.
http://www.mazdamp3.com/members/KYREDP5/clearcorners/clears1.jpg
http://www.mazdamp3.com/members/KYREDP5/clearcorners/clears2.jpg
http://www.mazdamp3.com/members/KYREDP5/clearcorners/clears3.jpg
http://www.mazdamp3.com/members/KYREDP5/clearcorners/clears4.jpg
http://www.mazdamp3.com/members/KYREDP5/clearcorners/clears5.jpg
I just wanted to get them done before it's supposed to start storming. I plan on going back and cleaning them up a bit later.
Edit: Links fixed (again)
I had to trim a hair off the top and bottom of the hole closest to the door.
I found some trim that will work perfectly. Just have to find some epoxy or something to hold it on there with. For those that care it's that black door trim that ppl put on the edges of their car door. Any suggestions for what epoxy to use? It'll post pics when I get back home tomorrow and get it put on. From just placing it on there it looks like it will be perfect.
nice kyredp5! I'd say go to the local autostore for the epoxy and get a good high temp so that s*** doesn't melt in the heat... Be sure to post the final picks. :D
I tried some "Fast set auto epoxy" But it didn't work very well. I'll have to try another one when I get home. I'll be sure to post pics tomorrow.
