Hi everyone. I'm new to the forum and new to engine work. I have a 02 Protege ES 2.0l. I bought this car and within a month it was leaking coolant into cylinder 1. The timing belt and water pump were replaced before I purchased the car. Also found that the thermostat was replaced.
My wife severely overheated the car and the leaking began into the cylinder. I purchased a gasket set and began the tear down. Sent the cylinder head out to the shop and has it shaved, and refurbed. They pressure tested it and said it was good. I cleaned the block and looked in all the cylinders and they looked fine. I replaced the headgasket but didn't check the block with a straight edge.
Replaced everything to the book specs (headbolts, cams etc.) Timing was good. Started the car back up and everything seemed good except the coolant reservoir was bubbling. I went for a 5 kms drive and parked the car. The bubbling was happening before I replaced the HG. Found that my rad was toast and would not seal at the rad cap, which was also replaced by me on the old rad. Purchased and installed a new rad and now the car is pumping out white smoke. Looked at my plugs and all of them are wet and looks likes burnt coolant in my cylinders.
What could have happened? Now the cooling system gets proper pressure and is making its way into the cylinders? I am regretting not just buying a new engine or atleast having the block looked at. I'm not sure what to do. I overpaid on the car and now have put another 600 into it. It's worth nothing to sell now and don't want to sell something with issues to something else.
Please help.
Please help.
