Removing MS6 front door panels
VRMS6
2011 Kona Blue Ford Edge Sport
As most of you know Im going to install heated mirrors on my VRMS6 sport. While waiting to get a repl drivers side mirror assy to repl the broken one that arrived last week I thought that installing the pass side would be a good idea...
Got the tweeter panel off no problem. Got the plate over the inner door lock plate off ok. 2 screws behind the trim for the door pull check. Even got the screw behind the puddle light without a hitch. Tried to then pull the panel off aqnd no go...Did I miss any screws?? I dont want to damage the panel so Im asking for any info you all may have....
Home | Account | Contact ALLDATA | Log Out | Help BASIL CHEVROLET
Select Vehicle | New TSBs | Technician's Reference Component Search:
Conversion Calculator
2006 Mazda Mazdaspeed6 L4-2.3L Turbo
Vehicle Level Body and Frame Doors, Hood and Trunk Front Door Panel Service and Repair
Service and Repair
Notes
FRONT DOOR TRIM REMOVAL/INSTALLATION
Driver's Side
Disconnect the negative battery cable.
Open the cap using a small screwdriver, then remove the screw.
Remove the inner handle cover.
Disconnect the door lock switch connector.
Remove the inner garnish
Remove the cover, then remove screw A.
Remove the lens cover, then remove screw.
Disengage clips A from the front door using a fastener remover.
Pull the front door trim upward, then disengage tabs B from the front door.
Disconnect the power door mirror switch connector and the power window main switch connector.
Remove the courtesy light.
Remove the front door trim.
Remove the switch panel from the front door trim.
Install in the reverse order of removal.
Passenger's Side
Remove the inner garnish.
Disconnect the door lock switch connectors
Disconnect the power window subswitch connector.
2008 ALLDATA LLC. All rights reserved.
Terms of Use
I will try and get the pics to work.
ok lets see if this works, hopes this helps
access to all data is one of the perks of being head mechanic and now manager of a shop. no problem hope it your heated mirrors work out. take some pics during proccess.
