Removing driver side headlight
UFO70
2003 MSP, Spicy Orange
I see a bolt on the right and a screw on the left, when you're facing the the car. But where are the other screws/bolts. The headlight still seems fixed in there pretty hard after removing these two screws.
Re: MSP HEADLIGHTS
XFACTOR6 said:
WILL THE P5 HEAD LIGHTS FIT ON MY MSP? WITH NO MODIFICATION?
THEY SHOULD FIT IN THERE QUITE WELL, BUT THE WIRING IS DIFFERENT BECAUSE THE PROTEGE5 USES TWO BULBS , ONE FOR REGULAR AND ONE FOR HIGH BEAM, WHEREAS THE MAZDASPEED PROTEGE ONES USE A SINGLE BULB.
P5 HEADLIGHTS
I READ IN ANOTHER POST THAT YOU CAN JUST BUY THE P5 HARNESS FOR IT , IS THAT TRUE ? THEN I COULD JUST PLUG AND PLAY RIGHT?
Man! It looks like a b*tch just to remove a light. How can you get air to move more easily into the engine when you're @ the tracks? I thought I'd remove the driver side headlight so there's cooler air for the intake. I guess that's not going to happen....
