Does anyone know the trick for removing the front interior (map) light panel from the headliner on a 2007 CX-7. I've tried plying it down but it doesn't seem to want to come loose.
I've removed mine using a blunt knife (perhaps a butter knife).
You work that up on the right hand side of the light unit (when looking from back), and feel for a metal clip. Push that in with the knife and the unit slides out a bit, enough for you to then pull it out
