Are you using the same spring rates as that MSP in the link? And what do you mean you're running softer springs in the rear so you can adjust your alignment for track days? I'm so confused...
Yes I am using about the same spring rates as the one in the link but I am running 600 front and 900 rear my old set up was 600 front and 1300 rear that was more of a stance set up. The reason I got new coils is when I am am Doen stancing my car I am going to track it. All I will need to do is get an alinement and throw it on 5 the track good to go
What rear sway bar are you running again? Because typically for FWD cars you want the rear to be as stiff as possible to get it to rotate and help reduce understeer.
Isn't the Racing Beat rear sway one of the lightest/thinnest rear sway bars? And I would be curious to see what tech says if/when you try to use this setup for a track day. They are pretty strict in making sure a car is safe before letting anyone on track.
I am not sure about the sway bar but I i should be ok to pass everything is pretty safe I just need to replace the spring seats in the rear still but I will take my time cause I made my old top hats work
