Radio won't turn on....
Sidewinder007
05 Mazda 6s
It all started with my CD player being jammed on my 05 Mazda 6. I took out my radio/cd player to clear the jam (piece of paper was stuck in there, don't ask how). Plugged in radio/cd player to make sure it still played CDs, worked perfectly. Turned off car. Next time I went to drive it the radio wouldn't turn on (also the 3 buttons below the radio (the AC button, Recirc Button, and the rear defroster button) do not light up anymore, and my LCD screen is blank.
I have tried everything I can think of. Checked all connections. Checked all fuses, even replaced the ones that I thought might lead to the radio (Room, Audio, etc). I also swapped the Audio relay with another one of the same kind (Fog I think) and still nothing.
I find it unlikely that the radio just went bad, so what else could it be? Also, even if the radio did go bad, would that stop the LCD display and the 3 buttons' lights to stop working also?
Thanks in advance for any help you may be able to provide!
take it back apart and make sure your connections are good. most likely something wiggled loose during reassembly. otherwise, fuse.
